The remote is unable to communicate with the RV-HUB Dock
RVBBT600 Please Wait.
If you are unable to control the Music function of your RV-BBT. Please follow these steps to reset the Wi-fi connection between your RV HUB Dock and display:
1. Place the display in the dock (Docking the RV HUB Remote).
2. Turn the motor coach's ignition to the on position and verify that the buttons on the RV-HUB Dock are illuminated.
3. From the Home screen, Select Settings.
RV-BBT600Settings 1
4. While holding the center of the screen, drag upwards and then Select Wi-Fi.
RVBBT600WifiSetting
5. Select RV-BBT600 Dock.
RVBBT600 Wifidock1
6. Select RESET.
RV-BBT600Resetwifi
7. Select OK.
RVBBT600 Wifi ok
The display will restore Wi-Fi connection with the RV HUB DOCK:
RV-BBT600wifisync
Update your RV Hub Dock and display by visiting the following articles:
How to update the RV-BBT601 Dock
Updating the RV-bbt601 Remote
If you need help operating your RV-BBT, please contact us at 1-800-253-5081 from 7:00AM to 7:00PM Central Standard Time (CST) Monday through Friday.
Please be near the device or coach so that we may be able to assist you better.
