The Time on My vivosmart 3 is Wrong
The vivosmart 3 updates the time when you sync with the Garmin Connect app on a smartphone or from Garmin Express on a personal computer. It is important that the time and date are correct on your smartphone or computer before syncing your device.
A sync via the Garmin Connect app should automatically occur once you open the app. If one does not occur, touch the sync icon
from the upper right corner of the My Day screen. If you are still unable to sync via these methods review our Garmin Connect App Bluetooth Troubleshooting FAQ for additional assistance with connecting your paired device with the app.
If you are encountering an issue with syncing using Garmin Express, review the following FAQ: Fitness Device Fails to Sync Successfully Using Garmin Express
I Synced My Device and My Time Is Still Wrong
This may indicate that the time setting on the device is set to Manual instead of Auto. To correct this issue, take the following steps:
Double tap the screen to wake it up.
Hold the touchscreen to view the menu.
Select
Select
Select Set Time.
Select Auto.
If the time was set to Manual perform another sync. This should correct the time on your device.
