Export Garmin Mechanic Diagnostic Data
Garmin Mechanic offers a limited ability to record a vehicle’s diagnostic output and export the data for use by external apps. By toggling the OBD button on the Trip tab , the app will begin recording the following information at high intervals:
- Vehicle Speed, measured in miles per hour
- Mass Airflow Rate, measured in grams per second
- Engine RPM
After the trip is complete, the data may be exported through the Vehicle Profile by following these directions:
- Start Garmin Mechanic
- Touch the Android device’s menu key
- Touch Trip History
- Touch the desired date and time with the recorded OBD data, denoted with the
symbol
- Touch Export to File, at the bottom of the screen
- The location in which the file will be created is displayed
- Press OK to export the data
The data may be accessed in the location provided at step 6. The data is in CSV (comma separated value) format.
