How to Search, Save, Edit, or Delete Locations on an Automotive Device
Choose a topic below for instructions on searching for, saving, editing, or deleting addresses or points of interest (POI).
To Search for an Address
1. Touch Where To?
2. Touch Address
3. Touch Spell City if the listed State is correct
    • Touch Change State/Country first if the Address is in another State or Country
Changing Country
After you change the country the device will automatically ask you to enter the state or province before returning to the Spell City page.
Enter State 3700
4. Enter City name and touch Done
5. Enter the House Number and touch Done
6. Enter the Street and touch Done
7. Select the street if necessary
The address should appear in the list of search results, select the correct destination from this list and touch Go.
To Search for a Point of Interest
1. Touch Where To?
2. Touch Points of Interest
3. Select a POI category (food, fuel, lodging, etc.)
4. Select a subcategory if necessary
5. Select the destination from the listed nearby POIs
6. Touch Go to calculate a route
After an address, POI or another type of destination has been found on your device, it is possible to save that destination so it can be easily accessed in the future. Once saved, the destination will be accessible from Favorites or Saved in the Where To? menu on the device.
To Save a Result
1. Search for an address, POI, etc., using the options available in the Where To? menu
2. When the location is found, select it from the search results
3. Touch the  info button
  • Skip this step on some devices
4. Touch the  menu button on the map screen
5. Touch Save
6. Enter a name for the location (if prompted)
7. Touch Done if prompted
8. Touch OK when notified the address has been added to Saved Places
Repeat steps to save additional destinations.
To Edit a Favorite
1. Touch Where To?
2. Touch Favorites or Saved
3. Touch the favorite you would like to edit
5. Touch Edit
6. Touch the information you would like to change
  • You may change the name, phone numbercategories, photo, and map symbol assigned to the location
Touch and hold the back button to return to the main menu.
To Delete a Favorite
1. Touch Where To?
3. Locate and touch the favorite you would like to delete
  • Some devices require you to touch the Info button (lower-case i) after this step
4. Touch the menu button (three lines) in the upper-left of the screen
5. Touch Delete
6. Touch Yes
The selected favorite(s) will now be deleted.
To Delete Multiple Favorites:
1. Touch Where To?
3. Touch menu button (three lines) in the upper left corner
4. Touch Delete Favorites or Delete Saved Places
5. Touch the location(s) you would like to delete
  • Touch Select All if you would like to delete all saved favorites
6. Touch Delete once the desired locations are selected
7. Touch Yes
Repeat the above steps as needed.
