Wireless Map and Software Update Instructions
A wireless connection to home high-speed internet (Fiber, Cable, DSL, etc.) is required to successfully complete a Wi-Fi update.
  • Connections with data caps or restrictions should not be used due to the size of a map update.
  • Slower connections (satellite, fixed wireless, dial-up, etc.) and mobile broadband (MiFi, AirCard, cell phone tethering, etc.) should not be used.
  • Captive portals are not compatible with the Tread® XL - Baja Chase Edition and Tread® XL - Baja Race Edition GPS navigators.
NOTE: See Not Enough Free Space for a Wireless Update if your device states there is not enough space for the wireless update.
See the Detailed Video Below to Learn about Wi-Fi Connections for Updates.
View the Following Video to Learn about Different Updates Available on Most Devices:
Check Out the Video or Follow the Steps Below to Update your Device.
NOTE: Not all devices come preloaded and/or are compatible with the maps below.
Current Map Version: 2026.10 (North America) as of February 12, 2025.
null
Current Map Version: 2026.10 (Europe) as of January 29, 2025.
To Connect the Device to a Wi-Fi Network:
1. Plug the device into a power source
2. Touch Apps
3. Touch Tools
4. Touch System Updates
5. Touch Access Wi-Fi Settings
6. Select a network
7. Enter the password for the network and select Connect
The device should then connect to the network. The network will be added to the list of saved networks. The device will reconnect to this network automatically when it is within range.
To Check For and Install Both Software and Map Updates on this Device:
NOTE: Updates will not be available if the device is on the latest version.
1. Touch Apps
2. Touch Tools
3. Touch System Updates
4. The device will check for available updates once connected to a Wi-Fi network. A prompt will appear to Download if any updates are available
NOTE: The device will be unusable until the updates complete.
Related
