Using Community Generated Road Hazards
During a ride with a compatible Edge® cycling computer, you can report a hazard that might be a potential risk to a cyclist. You can also confirm a hazard recognized by another Edge user, or report that the threat is no longer present.
Compatible Edge Cycling Computers
NOTE: This feature requires the latest software. Refer to this FAQ for updating software.
  • Edge® 540 | Edge® 540 Solar
  • Edge® 840 | Edge® 840 Solar
  • Edge® 1040 | Edge® 1040 Solar
  • Edge® 1050
Hazard Report Options
Below are the 5 types of reportable hazards and their possible use-cases. If a hazard is not voted on at all during the expiration window, they will disappear. Voting Yes ( Black check mark ) or No ( Black 'X' ) will either extend or decrease the time.
Hazard TypeDescriptionExpires In...
Animal
angry barking dog in red circle
Unleashed or aggressive dog, dangerous wildlife
180 Days
Obstruction
falling tree in red circle
Fallen tree, road closed7 Days
Pothole
Arrow pointing down into rectangle with a semicircle carved out of the top
Ruts or fractured road180 Days
Slippery
bike outline above three swerving lines
Mud, oil, fresh gravel1 Day
Hazard
White triangle with an explanation mark in an orange oval.
General category, construction 30 days
Reporting a Hazard During a Ride
At any point during a ride, report a hazard using these steps:
  1. Tap the screen to reveal the timer overlay.
  2. Select white triangle with an exclamation mark in an orange circle.
  3. Select the hazard type.
  4. Select Report.
    NOTE: You must select Report before the hazard report times out.
report hazard steps with screenshots on edge
Viewing a Hazard
if another rider has reported a hazard and then synced with Garmin Connect™ , the hazard will be present for other riders in the area. The hazard will be indicated upon approaching its location, if browsing the map on the edge, or creating a course in Garmin Connect.
Enabling or Disabling Hazards
Hazard Alerts are enabled by default, however you can adjust the alerts based on the activity profile:
NOTE: You will always have the option to report a hazard, however receiving the alerts may be disabled using the steps below.
  1. Select Three horizontal lines in red circle .
  2. Select Activity Profiles.
  3. Select a profile.
  4. Select Alerts and Prompts.
  5. Select Road Hazard Alerts.
Receiving Alerts and Voting
During your ride, you will be notified of a hazard nearby if you are within 250 meters, and if you pass it within 25 meters, you will have the ability to vote on if the hazard is ( check mark  for yes )or is not ( x mark icon ) still there. edge asking if pothole is still there
Do I Need To Be Paired to Garmin Connect?
The feature requires the Edge be connected to a compatible smartphone with the Garmin Connect™ App in order to receive hazard location data and participate in votes. If the Edge was paired to the Garmin Connect app prior to riding, but the phone connection is not available during the ride, votes will be stored and uploaded to Garmin Connect when phone connection is restored.
Hazards During Course Creation
When creating a course in Garmin Connect, you will be able to see potential hazards. Enable the map layer by selecting Two black squares layered on top of each other and then toggle Hazards.
NOTE: After you have finished editing a course, any hazards along the course will still appear on the map, regardless of whether the hazard toggle is enabled in the edit screen.
 hazards on course when creating in the app
Community Hazards Video
