Important Notice: Beware of Fake Garmin Ads!
Garmin Malaysia has received reports of fraudulent websites and advertisements circulating on social media, claiming to sell Garmin products at discounted prices. Do not click on suspicious links or provide personal information on unverified sites.
Always shop through the official Garmin website. Your safety is our top priority.
Purchasing and Replacing QuickFit 20mm Spring Bars for Select Garmin Watches
Garmin® watch band pins (or spring bars) are designed to work with our QuickFit® bands and to keep your watch band secured to the watch.
If you need replacement band pins they can be purchased on Garmin.com.
These new band pins are only compatible with the following watches:
  • Approach® S44
  • Approach® S50
  • Approach® S70 - 42 mm
  • Descent™ Mk2S
  • Descent™ Mk3 – 43 mm | Descent™ Mk3i – 43 mm
  • epix™ Pro (Gen 2) - Standard Edition - 42mm | epix™ Pro (Gen 2) - Sapphire Edition - 42mm
  • fēnix® 6S - Standard Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition
  • fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
  • fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
  • fēnix® 8 - AMOLED Edition 43 mm
WARNING! The band pin cannot be removed without cutting it. For this reason, Garmin recommends you take your watch to a jeweler or other professional to replace the band pin. Damage done to your watch while replacing the band pin may not be covered under Garmin's warranty.
Requirements
The following items are needed to replace the band pin:
  • Your Garmin watch
  • A wire cutter
  • Replacement band pin(s)
Select an option below to reveal steps.
Removing the Band Pin
Where to Cut
Cutting Area for fenix 7 Band Pin
Cutting the Band Pin
The band pin will need to be cut to be removed. Cut the band pin using the wire cutter.
Replacing the Band Pin
The band pin is spring loaded. Once it is in place, it can not be removed without cutting it. If you are using a third-party band with your watch that does not have a Garmin compatible QuickFit mechanism, you will need to put the band on the band pin before you secure the band pin to the watch housing.
  1. OPTIONAL: Put the band pin through the pin hole of your third-party watch band.
  2. Align one end of the band pin into the hole in the arm of the watch body.
  3. Depress the spring loaded part of the band pin that has not been aligned with the watch body and push into the hole on the opposing arm of the watch.
    fenix 7 Band Pin Replacement Step 2
  4. Attach the Garmin QuickFit band to the band pin.
    fenix 7 Band Pin Replacement Step 3
