microSD Memory Card Compatibility for Garmin Dash Cams
Garmin Dash Cam™ driving recorders require a compatible memory card to record video or take pictures because the device does not have internal memory for storing files. This includes:
- Garmin Dash Cam™ X110 driving recorder¹
- Garmin Dash Cam™ X210 driving recorder¹
- Garmin Dash Cam™ X310 driving recorder¹
- Garmin Dash Cam™ Live driving recorder
- Garmin Dash Cam™ 46 driving recorder
- Garmin Dash Cam™ 47 driving recorder
- Garmin Dash Cam™ 56 driving recorder
- Garmin Dash Cam™ 57 driving recorder
- Garmin Dash Cam™ 66W driving recorder
- Garmin Dash Cam™ 67W driving recorder
- Garmin Dash Cam™ Mini driving recorder
- Garmin Dash Cam™ Mini 2 driving recorder
- Garmin Dash Cam™ Mini 3 driving recorder¹
- Garmin Dash Cam™ Tandem driving recorder
¹These models do not take pictures or respond to the "OK Garmin (or OK Dash Cam) Take a Picture" voice command.
Recommended microSD Memory Cards:
When choosing a memory card, select one specifically designed for dash cams. These cards offer greater endurance and can withstand continuous read-write cycles. Additionally, they are engineered to handle the extreme temperatures and vibrations commonly encountered in a vehicle.
NOTE: Use only authentic microSD cards with thickness specs 0.7mm +/- 0.1mm to avoid slot damage.
Memory cards that may serve this purpose include those listed below. Before making a decision, it’s advisable to examine the manufacturer’s specifications and warranty to ensure that the product aligns with your intended purpose.
Brand | Family |
ADATA | High Endurance |
Samsung | Pro Endurance |
SanDisk | High Endurance Max Endurance |
Transcend | High Endurance |
Note that if a memory card is used in a way that is not recommended by its manufacturer without being specifically designed for it, such as use in a high-endurance environment like a dash cam, the manufacturer's warranty might not cover any resulting failure or replacement.
microSD Card Specifications:
Minimum Capacity | Maximum Capacity | Card Types | Speed Class |
8 GB | 512 GB | microSD, microSDHC, microSDXC | Class 10 (or faster) is required |
Compatible microSD cards can be purchased from Garmin or other retailers.
Memory cards wear out after they are overwritten a large number of times.
- Your device detects memory card errors automatically and alerts you when it is time to format or replace your memory card
- Consider having a backup compatible memory card available to easily replace if needed.
To Extend the Useful Life of your microSD card, Garmin Recommends the Following:
Back up saved video and format the memory card at least once every 6 months.
For instructions, see your device's Owner's Manual.
Replace the memory card periodically due to the dash camera recording continuously.
Turn off the device when your vehicle is not in use to prevent the dash camera from recording unneeded footage.
This does not apply while using Parking Guard or Parking Mode. For more info. see Differences Between Parking Guard and Parking Mode Features.
Use a memory card with a higher storage capacity.
Higher-capacity memory cards are overwritten less frequently and will usually last longer.
Use a high-quality authentic memory card with a speed rating of class 10 or faster.
Purchase your replacement memory card from a high-quality manufacturer and a reputable vendor.
Recording Modes, Video Resolutions and File Sizes:
For specifications on microSD Card Recording Modes, Video Resolutions, and File Sizes for your Garmin Dash Cam, see:
microSD Card Recording Modes, Video Resolutions, and File Sizes on the Garmin Dash Cam 46
microSD Card Recording Modes/Length, Video Resolutions, and File Sizes on the Garmin Dash Cam Tandem
microSD Card Recording Modes, Video Resolutions, and File Sizes on the Garmin Dash Cam Mini
NOTE: microSD memory cards are not included with some Garmin Dash Cam devices. Device packaging and the Specs product pages on www.garmin.com will advise which ones include them.
