Changing the Screen Brightness on an Automotive Device/Dim or Black Screen
Some devices will not go above 40% brightness when they have low power. This FAQ may also be helpful if your device has a black screen or a very dim screen. To correct this, plug the device into a power source and follow the instructions below.
The device may have a different brightness level set when it is plugged in and unplugged. If the device goes dim when plugged into the vehicle, follow steps 1-3 below before plugging it in. Once it is plugged in, if it goes dim, you can swipe right on the screen to brighten it using step 4.
Some devices require the brightness settings to be adjusted and saved separately while plugged into the vehicle, then adjusted again unplugged from the vehicle.
View the Detailed Video or Follow the Instructions Below.
To Change the Screen Brightness:
1. Touch Settings
2. Touch Display (You may have to scroll down to see it)
3. Touch Brightness
4. Adjust the brightness level according to your preference. The screen will dim to the selected brightness while moving the selector.
Depending on the device, the saved brightness level may need to be adjusted for Day and Night Mode:
Day Mode - Provides a white background to improve visibility during daylight hours.
Night Mode - Darkens the background to prevent the screen from being too bright or distracting when driving in the dark.
To Change the Color Mode:
1.Touch Settings
2. Touch Display
3. Touch Color Mode
4. Touch the desired color mode and touch Save
