Getting Started With Outdoor Maps Plus on a Compatible Tread Device
With an Outdoor Maps+ annual subscription, you gain access to a wide variety of premium mapping content. This content is regularly updated. A subscription can be activated allowing mapping content to be downloaded directly to a compatible device via Wi-Fi. The topics below explain how to activate, download, and use the different types of mapping content that are available with Outdoor Maps+.
NOTE: The software on the device must be up to date to activate and download Outdoor Maps+ Content.
Outdoor Maps+ is compatible with the following devices:
Scroll down to the bottom of the map layers and select the Subscribe button
Select and purchase an Outdoor Maps+ plan
Once the activation completes, you can proceed with downloading Outdoor Maps+ content to the device. (Activation will complete on its own shortly after purchase).
After activating an Outdoor Maps+ annual subscription, the following steps can be used to download content via Wi-Fi. These steps can be repeated to download multiple areas of the map.
NOTE: The software on the Tread device must be up to date to download Outdoor Maps+ Content.
To Download Outdoor Maps+ Content on a Tread® - Overland Edition, Tread® - SxS Edition, Tread® XL - Overland Edition, Arctic Cat G8 Display, and Kawasaki RIDGE 8" Tread Display:
Select Settings
Select Map Display
Scroll down and select Map Manager
Select Outdoor Maps+
Select Download Maps
Pan around the map to highlight the desired download area within the black boarder on the map screen
Zoom in and out of the map using the and symbols to control the size of the area being downloaded; the area chosen and zoom level will determine the size of the download and map layers available
Available storage space will be listed at the top of the page. Select the icon to choose map content to download
Select the desired map layers to download
Select the icon above a map layer to get a description of the layer
After choosing the desired map layer(s), select the back arrow in the lower left corner of the screen
When the desired download area is within frame and all desired map layers have been chosen, select the download icon
Prior to downloading, select the icon to choose if the download is saved to internal storage or an external memory card
The download will begin. Wait for the download to complete or begin downloading more content if desired
While the download is in progress, make sure to keep the device powered on and in range of the connected Wi-Fi network. Depending on the speed of the Wi-Fi network, each download may take several minutes to complete.
To Download Outdoor Maps+ Content on a Tread® XL - Baja Chase Edition | Tread® XL - Baja Race Edition GPS Navigator:
Select Apps
Select Tools
Select Settings
Select Map Display
To Download Outdoor Maps+ Content on a Tread® 2 GPS Navigator:
Select Apps
Select Map Manager
Installed Outdoor Maps+ content can be edited to remove or add additional map layers when using the device for different activities. You can rename downloaded Outdoor Maps+ content, delete the downloaded content, or download/delete layers from the downloaded content area(s).
Go to Map Manager
Select the desired Outdoor Maps+ download to edit
Select Name to rename the download if desired
Select Delete to delete the download if desired
Select Map Layers to delete or add additional layers to the download area if desired
'Download area' is the region that was highlighted for the original Outdoor Maps+ download that was created
When purchasing an Outdoor Maps+ annual subscription, there is an option to enable automatic annual renewal. If you need to update your payment information or cancel automatic renewal, this can be done by visiting garmin.com/subscriptions and signing into your Garmin account. For more details, see Managing My Outdoor Maps Plus Annual Plan.
