Deleting Tracks From An inReach Explorer+ or SE+
There are several reasons why you may find the need to delete the tracks on your inReach SE®+ or inReach Explorer®+ handheld:
  • Free up space to record a new track.
  • Map screen cluttered by an old track.
  • Confusing the old track on the map with the currently-recorded track.
  • Tracks reappearing after being deleted on the Garmin Explore™ website.1
IMPORTANT: Following these steps permanently deletes the data, and it will no longer be in the inReach device. If data is deleted on the device before it has been synced to the Garmin Explore website, the data will be permanently deleted and cannot be recovered.
Deleting Tracks
Track points can be deleted in the history menu and track lines can be cleared from the tracking page.
Deleting an Entire Day of Track Points
You can quickly delete an entire day of track points.
  1. From the Main menu, select History.
  2. Tracks are sorted by the date they were recorded, select one from the list.
  3. Press Three Lines.
  4. Select Delete Day.
    NOTE: This will also delete any messages and waypoints done that same day.
Deleting Individual Track Points
You can delete individual track points. This is useful if you are needing to delete track points, but do not want to delete an entire day of history.
  3. Select the desired track point to delete.
  4. Press Three Lines.
  5. Select Delete.
Clearing the Track Log
Clearing the track log removes previous track lines from the map screen.
  1. From the Main menu, select Tracking.
  2. Select Clear.
  3. Select Clear again to confirm.
  4. Select an option:
    • Reset Trip: Clears trip values and speeds.
    • Reset All: Clears trip values, speeds, and odometer.
The track log will now be cleared.
NOTE: You may still see a percentage of the storage taken up on the tracking page after selecting clear. This is due to having routes on the device.
1 If tracks are reappearing on the device or on the Garmin Explore Website, see - Deleted Data Reappearing on the Map of the Garmin Explore Website.
