Replacement Watch Bands for Garmin Approach S60
A replacement band can be ordered on Garmin’s website to update the look of your watch or replace a band.
The watch bands that fit your Approach S60 can be found using the link below and expanding the + Bands line.
null
null
Replacing the Approach S60 Watch Band
Replacing the QuickFit band on your Approach S60 takes just a few steps. QuickFit bands are designed to be changed very quickly, and without tools.
Removing the Band
  1. Locate the latch on the band near the housing of the watch.
  2. Pull the latch away from the housing of the watch and lift the band from the pin
Replacing the Band
  1. Pull down on the latch on the band
  2. Place the band on the pin and release the latch
You have successfully changes your QuickFit band.
