- eTrex Venture® Cx and HC
- eTrex Summit® HC
- eTrex Legend® H, C, Cx, and HCx
- eTrex Vista® H, C, Cx, and HCx
- GPS 60
- GPSMAP® 60-series
Changing eTrex, GPS 60, GPSMAP 60 Postion Format
To change the settings on the GPS unit please do the following:
- Go to the Menu
- Select Setup
- Select Units
- Highlight the entry under Position Format and press Enter
- Highlight British Grid as an example and press Enter
The entry under Map Datum should now state Ord Srvy GB. If this has not changed automatically, highlight the entry and press Enter then select Ord Srvy GB from the list.
The device will now give you a 10 figure grid reference for use in conjunction with an Ordnance Survey map.
