Syncing, Adding, and Deleting Garmin Explore App Data on the Tread
The Garmin Explore™ account is an intermediary tool for creating, deleting, and transferring data to and from the Tread® and Tread® - Base Edition GPS navigators.
You must connect to the Tread® App and enable Garmin Explore to sync your Garmin Explore account data with the Tread. See Installing and Pairing the Tread App for instructions.
NOTE: When using the Tread series devices, it is recommended to use the Tread app for creating and managing waypoints, routes, and tracks. The Garmin Explore™ website can be used to manage waypoints and tracks, but does not support route creation for the Tread devices.
You will need to use the email address from your Garmin Explore account when signing in to the Tread App. Any edits to the data can be made in the Tread app. The Tread will not pair to the Garmin Explore™ app on your smartphone.
The Garmin Explore website and mobile app will wirelessly sync data with each other and the Tread. Information that is added or deleted from the Garmin Explore account from the website or app will then be added or removed from the Tread the next time it syncs to the Tread app. If your smartphone does not have an active internet connection, it will not be able to sync.
See Synchronizing Garmin Explore Account Data for instructions to sync data from your device with your Garmin Explore account.
To Delete Garmin Explore Data on the Tread and Tread - Base Edition:
  1. Touch Explore.
  2. Select a category.
  3. Touch the Wrench icon.
  4. Touch Delete
  5. Select items to delete.
  6. Touch Delete
  7. Touch Yes
See the Detailed Video Below for More Information on Accessing and Sharing Garmin Explore Data on your Tread.
Related
