You are viewing an article that is not available in your currently selected language. You can choose another one below.
Automatic Hole Transition on a Garmin Forerunner 935
All Garmin golf capable watches will automatically transition to the upcoming hole when brought near the hole's far back tee box.
If for any reason the device does not automatically transition, transitioning can be done manually.
Manually Transition Holes on Fitness Multisport Watch1:
- Press the Up button to move forward or press Down button to return to a previous hole
Doing this may be necessary if the device does not transition automatically or if it jumps to the next hole earlier than desired.
1 Fitness Multisport watches include: Forerunner 935
