Adding an Alarm to My vivosmart HR
The vivosmart HR has the ability to provide an alarm notification in the form of a vibration alert. You are able to set the alarm through device settings in the Garmin Connect web or app.
Add an Alarm in the Garmin Connect App
Open the Garmin Connect app.
Access the menu by selecting More (bottom right).
Select Garmin Devices.
Select vivosmart HR.
Select Device Settings.
Select Alarm.
Toggle Alarm on.
Set Time and Frequency.
Select the back arrow to save the changes.
Sync your device.
The alarm is now set on the vivosmart HR.
Add an Alarm Using Garmin Connect Web
Sign into Garmin Connect from a personal computer.
Select
(top right).
Locate the vivosmart HR.
Go to Sounds & Alerts.
Add an Alarm.
Select Save.
Sync your device.
