Garmin Dash Cam Memory Card Error Messages
NOTE: microSD memory cards are not included with some Garmin Dash Cam devices. Device packaging and the Specs product pages on www.garmin.com will advise which ones include them.
The following Garmin dash cams will continually record footage and temporarily save it to a microSD memory card inserted into the device. As the memory card's capacity fills up, the device will begin to overwrite unsaved data.
- Garmin Dash Cam™ X110 | Garmin Dash Cam™ X210 | Garmin Dash Cam™ X310 driving recorders
- Garmin Dash Cam™ Live driving recorder
- Garmin Dash Cam™ 47 | Garmin Dash Cam™ 57 | Garmin Dash Cam™ 67W driving recorders
- Garmin Dash Cam™ 46 | Garmin Dash Cam™ 56 | Garmin Dash Cam™ 66W driving recorders
- Garmin Dash Cam™ 45 | Garmin Dash Cam™ 54 | Garmin Dash Cam™ 55 | Garmin Dash Cam™ 65W driving recorders
Saved videos, either from manual saves or incident detection, will not be overwritten by this process. For more information, refer the Dash Cam Owner's Manual.
MicroSD memory cards have a limited number of times that they can completely overwrite previous data before wearing out. While this number is generally high, it is possible to reach this limit over the life of the Garmin Dash Cam as it continuously records new video files.
The Error Messages Below can Appear on the Garmin Dash Cam to Indicate the Status of the Memory Card:
- "The memory card is degrading and video may be lost. Replace the memory card soon."
- Pressing the
Select button should bypass this message; it is still advisable to replace the card soon.
- If the Select button does not allow the device to proceed, the microSD card must be replaced to continue using the device.
- Pressing the
- "The memory card is slowing down. Formatting the card might extend its useful life."
- If the memory card is new, it may be defective or of a quality level not suitable for high-endurance continuous recording. Check Compatible SD Cards below to ensure the card is compatible.
- If the memory card has been in use, it may need reformatting. See Related content below.
- "The memory card has reached the end of its useful life and can no longer record videos. Insert a new memory card to begin recording."
- The microSD card must be replaced to continue using the device.
So that you will be alerted with a message when the time comes, ensure your dash cam software is up to date.
For help updating your dash cam software:
- Go to: Garmin Support Center
- Enter your dash cam model or serial number
- Then, click on the Software option on the left
The Garmin Dash Cam Must use a Class 10 or Higher MicroSD Memory Card and has the Following Limits:
- Garmin Dash Cam Mini 3, Garmin Dash Cam X110, Garmin Dash Cam X210, Garmin Dash Cam X310:
- 8 GB up to 512 GB
- Garmin Dash Cam 47, Garmin Dash Cam 57, Garmin Dash Cam 67W, Garmin Dash Cam Mini 2, Garmin Dash Cam Live:
- 8 GB up to 512 GB
- Garmin Dash Cam 46, Garmin Dash Cam 56, Garmin Dash Cam 66W, Garmin Dash Cam Mini:
- 4 GB up to 512 GB
- Garmin Dash Cam 45, Garmin Dash Cam 54, Garmin Dash Cam 55, Garmin Dash Cam 65W:
- 4 GB up to 64 GB
Larger cards will last longer, as it will take longer to completely fill and overwrite the card.
Compatible SD Cards:
- For most Garmin Dash Cams see: SD Memory Card Compatibility for Garmin Dash Cams
- For Garmin Dash Cam 45 and Garmin Dash Cam 65W see: SD Memory Card Compatibility for Garmin Dash Cam 45 and Garmin Dash Cam 65W
- For Garmin Dash Cams 54 and Garmin Dash Cam 55 see: SD Memory Card Compatibility for the Garmin Dash Cam 54 and Garmin Dash Cam 55
