Firmware updates for the hub and Cortex™ H1/H1P handsets are bundled with the Cortex Onboard™ App releases. Check the Google Play Store for updates to Cortex Onboard and select UPDATE, if available.
For more about what to expect from the update, see Related Content.
Once downloaded to the mobile device, follow these steps
1. Connect the mobile device to the M1 Wi-Fi on the vessel
2. Press the Wi-Fi icon
3. Press the Config Icon
4. Press select, and the device will look for the QR code
5. Point the camera at the QR code that is in the box with the M1
Once the app has connected, it should ask to confirm the update. If not, do the following:
1. Push the menu icon (top left) and then
2. Push the center of the top banner
3. Select Cortex® Updates...
The M1 will automatically recognize updated firmware and the Onboard App will ask to perform the firmware update. Select Yes to update and the status bar will indicate the update status.
NOTE: If the Cortex is registered, emails will advise when a firmware update is available.
