What Does Each Button Do On the Varia Remote?
Here is an explanation of the buttons and lights on the Varia Remote.
- Taillight button. Select to signal a left turn when using two taillights. Hold to change taillight operating modes.
- Headlight button. Select to switch between low beam and high beam. Hold to change the headlight operating modes.
- Taillight and power button. Select to signal a right turn when using two taillights. Hold to turn all lights on and off.
- Status LED.
NOTE: The turn signal feature is only available on the Varia TL 300.
What Does the Status LED mean?
- Flashing green: Searching for a paired device.
- Alternating red and green: Attempting to pair with a device. A turn indicator is on.
- 12 rapid green flashes: Successfully paired with a device.
- Solid red: Pairing failed or the connection was lost.
- Flashing red: One or more of the paired devices has a low battery.
