Dakota® 10 | Dakota® 20
eTrex® 20 | eTrex® 20x | eTrex® 22x | eTrex® 30 | eTrex® 30x | eTrex® 32x
eTrex® Touch 25 | eTrex® Touch 35 | eTrex® Touch 35t
GPSMAP® 62 | GPSMAP® 62s | GPSMAP® 62sc | GPSMAP® 62st | GPSMAP® 62stc
GPSMAP® 64 | GPSMAP® 64s | GPSMAP® 64sc | GPSMAP® 64st | GPSMAP® 64sx | GPSMAP® 64csx | GPSMAP® 64x
GPSMAP® 65 | GPSMAP® 65s
Montana® 680 | Montana® 680t
Oregon® 200 and all other models in the Oregon series
Rino® 610 | Rino® 650 | Rino® 650t | Rino® 655t
Rino® 700 | Rino® 750 | Rino® 750t | Rino® 755t
Setting Up an Off-Course Alert on an Outdoor Handheld Device
Most newer outdoor handheld devices offer an option to set up a course alert or an off-course alert while navigating to a waypoint or along a route. This will result in the device beeping to alert the user that they have deviated a certain distance from the course.
NOTE: Your device may require a software update before seeing the option for setting up course alerts. See, Installing Software Updates to Outdoor Handhelds.
Steps for Devices With Course Alerts
Select Setup from the main menu.
Select Routing.
Toggle Course Alerts on.
GPSMAP® 66i | GPSMAP® 66s | GPSMAP® 66sr | GPSMAP® 66st
GPSMAP® 67 | GPSMAP® 67i
GPSMAP® 86i | GPSMAP® 86s | GPSMAP® 86sc | GPSMAP® 86sci
Montana® 700 | Montana® 700i | Montana® 710 | Montana® 710i | Montana® 750i | Montana® 760i
Steps for Devices With Off-Course Alerts
Select Marine.
Select Marine Alarm Setup.
Select Off Course Alarm
Select On.
Enter the appropriate distance (how far off-course to be notified at).
- Select the Green Check Mark or Done.
The off-course alert is now setup. When the user moves away the specific distance from the course, the device will beep.
