Routes button on automotive devices
A button labeled "Routes" will appear when you touch an address or Point of Interest (POI). When you touch the Routes button, the device will display the map screen and calculate multiple routes to your destination.
The device will calculate routes in this order: Faster Time (blue route), Shorter Distance1 (yellow route), and then Less Fuel (purple route).2 The box on the right-hand side of the map will only allow you to preview each calculated route by using the right and left arrows. The box will also display the details about each route option, including the estimated driving time, the total driving distance, fuel cost,2 and any known traffic delays.3
Once the desired route option has been selected, touch Go! to activate that route. Selecting a calculation mode other than the one in the device's navigation settings does not permanently change this setting and will only affect the current route.
1If the route for Shorter Distance is the same as the route calculated for Faster Time, only Faster Time will appear.
2Less Fuel calculation mode and fuel cost are only available if the ecoRoute HD accessory is active on your device and you have completed a vehicle profile.
3Traffic delay information only appears when using a traffic receiver in a traffic coverage area on a compatible device.
