(2022) Service Bulletin 21116 Rev D: G1000 NXi STC Software Update v2286.14 for 200/300 Series Aircraft
PRODUCTS AFFECTED:
All Textron Aviation Inc. (Beechcraft) King Air 200 and 300 series aircraft equipped with G1000 Integrated Flight Deck per STC SA01535WI-D with system software versions 2286.06 through 2286.13 and equipped with all of the following LRUs:
- GIA 64E
- GMA 1360D
- GEA 71B
- GRS 7800/GDC 7400 or GSU 75B
CERTIFICATION AUTHORIZATION:
STC SA01535WI-D
COMPLIANCE:
Optional: This STC Service Bulletin may be incorporated at the owner’s discretion.
PURPOSE:
This service bulletin provides notification of an available update to System Software Version 2286.14 and includes the following changes:
NOTE
With this update, the ‘FDR with GIA64 Option’ configuration – intended to support a 3rd party FDR STC - was removed from the software image. In the future, a separate supplemental loader image will be created that contains the updated GIA 64 FDR configuration.
- Support for -05 GEA™ 71B LRU (allows removal of existing Meggitt Signal Conditioners)
- Support for -01 GTX™ 345R LRU (end-of-life planning only, no functional change)
- Improvements to EIS transient indications for Prop RPM, Torque, and ITT
- Addition of new features:
- Standby Flight Plans
- (Advisory) VNAV Guidance for Non-Precision Approaches
- Fast Find
- Support for direct (analog) interface to Collins ALT-50A or ALT-55B Radio Altimeter
- GSU 75 software update to address susceptibility to reset in certain ground circumstances when operating without GPS aiding
- GSA 9XXX software and Rudder Boost performance updates (300/B300 only)
- Gain file updates for VNAV acknowledgment timeout and transition to approach force capture threshold improvements
