Using Birdseye Satellite Imagery on the Overlander
With the 3.70 software update, the Garmin Overlander® GPS navigator is now compatible with BirdsEye Imagery.  See Wireless Map and Software Update Instructions for instructions to update the software.  The US only Aerial satellite imagery is already available to download and use in the Garmin Explore™ App on the Overlander.  However, BirdsEye Imagery can be installed if you need to use satellite imagery in the Garmin Drive™ App. BirdsEye Imagery may not be desirable in all scenarios.
To Enable/Disable BirdsEye Imagery in the Map Layer Settings:
  1. Select Gear Icon
  2. Select Navigation
  3. Select Map and Vehicle
  4. Select Map Layers
  5. Select Custom Maps
    • BirdsEye images are considered Custom Maps.
  6. Select OK
To Enable/Disable BirdsEye Imagery in the Drive Screen:
  1. Select Drive
  3. Select Custom Maps
See Purchase, Activate, and Download BirdsEye Products Overview for more details on purchasing, activating, and downloading BirdsEye Imagery.
Related
