Body Battery Frequently Asked Questions
If you have a watch that provides a Body Battery reading, you can track your overall energy level on a daily basis on your watch and from the Garmin Connect app.
What is the Body Battery Energy Monitor?
Body Battery is a feature that uses a combination of heart rate variability, stress, and activity to estimate a user’s energy reserves throughout the day. It records and displays a number from 1-100 that represents the individual’s energy level.
The higher the number, the more energy the user should have to complete tasks and activities. A lower number may indicate it is time to conserve energy. The unique aspect of Body Battery is that it is a cumulative metric that builds a picture of a user’s energy over hours and days.
Body Battery Widget
Which Garmin Watches Have the Body Battery Feature?
Select the list below to reveal models compatible with this feature.
Compatible Watch List
    • Approach S62
    • Enduro series
    • epix (Gen 2) series
    • fenix 6 series
    • fenix 7 series
    • Forerunner 245 / 245 Music
    • Forerunner 45 / 45S
    • Forerunner 55
    • Forerunner 745
    • Forerunner 945
    • Forerunner 945 LTE
    • Garmin Swim 2
    • Instinct series
    • Instinct Solar series
    • Lily series
    • MARQ collection
    • quatix 6
    • tactix Delta series
    • Venu
    • Venu 2 and 2 Plus series
    • Venu Sq series
    • vivoactive 4 / 4S (including Legacy Hero and Saga watches)
    • vivosmart 4
    • vivomove 3 series (including Luxe, Sport, and Style watches)
Why Is This Information Important?
Body Battery can be used to help manage a user’s day. When the number is high, it should mean the user has enough energy for a workout or exercise. Conversely, when the value is low, it may be a good idea to conserve and rest.
It can also be used to learn how the body reacts to various situations and stimuli. For example, if the Body Battery shows a low number in the morning, the user may be able to look at the past few days of cumulative measurements to identify what may have been the cause.
Should My Body Battery Always Be High?
Not necessarily. The Body Battery should generally be highest after waking up from a restful night’s sleep, then drain naturally as the user goes about the day. Vigorous activity will drain the battery faster, but this is not necessarily a bad thing. Regular exercise, activity, and recovery should increase the body’s resiliency and stamina over time.
Body Battery can be used to help manage when and how long exercise can happen, as well as encourage enough recharge to handle an upcoming activity or a busy day.
What Do Charged and Drained Mean?
For compatible products, charged and drained are displayed in Garmin Connect, showing how many points of Body Battery was recharged or recovered vs. how many were spent or used up. Ideally, there should be a similar level of each at the end of the day, indicating a balance of activity and recovery. Too much of one without the other is not recommended.
Body Battery card
How Do I Recharge My Body Battery?
Wearing the watch to bed and getting a good night’s sleep is the best thing to do to charge. Try to avoid things that hinder restful sleep such as caffeine, alcohol, or exercising too close to bedtime as those will delay recovery.  Eating healthy, while always a good idea, does not directly impact the Body Battery metric. Similarly, energy shots or other caffeine-based drinks may increase alertness temporarily but do not actually increase Body Battery or slow down your Body Battery drain.
Why Is My Body Battery Still Low After Sleeping?
Your perception of how you feel and the cumulative effect of stress and sleep quality may not always be in alignment. This is especially true if you have multiple days in a row that hit the upper or lower limit of the Body Battery. Other factors including tossing and turning or waking up frequently at night, which can result in a lower score in the morning.
My Body Battery Appears to Be Stuck at 5%
If you have a new device, or if you recently reset or restored your device to its factory default settings, it may require 5-7 days to learn or re-learn your body. During this time, you may see the Body Battery stuck at 5%.  If you reset the watch (again), this 5-7 day period will start over. After about a  week, the Body Battery should charge and discharge as expected.
What Happens When I Do Not Wear My Watch?
The Body Battery metric will estimate the charging or draining during short periods when the device is off. If you do not wear it for several hours or longer, the value will reset based on a model and continue from that point once worn.
After wearing the device continuously for a full day, the values should correlate closely to what your Body Battery should be. The more you wear it, the more accurate it should be.
What Else Affects My Body Battery Besides a Workout?
Anything that can affect your heart rate variability can accelerate your Body Battery drain or slow down a charge. This can include physical and emotional duress as well as sickness. Other factors include elevated heart rate, both all-day and during exercise. If your watch is detecting an elevated heart rate and stress, this will cause your Body Battery to drain.
What if I Train With Another Garmin Device That Does Not Have Body Battery?
We recommend wearing your watch along with your other Garmin device to ensure continuous Body Battery measurements. Information recorded from a device that does not feature Body Battery will not be included in the Body Battery calculation.
How Does Body Battery Interact With Activity and Stress?
The chart below details certain activities, habits, and stresses that affect Body Battery.
External Physical FactorsPositive Emotions
  • Alcohol/Stimulants
  • Excessive Physical Activity
  • Extreme Temperatures
  • Bright Light/Loud Noises
  • Anticipation
  • Exhilaration
  • Thrill/Excitement
  • Joy
Internal Physical FactorsNegative Emotions
  • Infection/Disease
  • Pain
  • Dehydration/Indigestion
  • Exhaustion
  • Anxiety
  • Fear
  • Sorrow
  • Being Overwhelmed
NOTE: Food intake and/or caffeine is not expected to show a recharge in your Body Battery even though you feel that you have more energy after consumption. Stimulants (such as caffeine) may actually indirectly result in a lower Body Battery (over time) if intake occurs at a time where sleep could be affected, as sleep time is the most crucial time for Body Battery to recharge.
Additional information for Body Battery can be found in the Garmin Blog:
Related
