Remove and Add a Device From the Garmin Golf App
Follow each step below to remove (unpair) and add (pair) a device from the Garmin Golf™ app.
Removing a Device From the Garmin Golf App
Open the Garmin Golf app.
Select Profile.
Select My Devices.
Select the device you would like to remove.
Press
in the top right corner.
Select Remove Device.
The device may still be paired under the Bluetooth® settings of your mobile device. You may have to remove the device from these settings as well. Settings vary based on the model of your mobile device. Consult your device's owner's manual for specific steps.
Adding a Device to the Garmin Golf App
Select Profile.
Select My Devices.
Select Add Device.
Choose your device.
Place your Garmin device into pairing mode. This allows the Garmin Golf app to find it.
This setting is typically found under Settings > Bluetooth or Phone > Pair Mobile Device or Pair Phone. Refer to your owner's manual for specific steps.
From the Garmin Golf app, select Start.
Input the six-digit code showing on the display of the Garmin device into the prompt on your mobile device.
Follow the onscreen prompts to complete the setup of your Garmin device.
The device is now paired with the Garmin Golf app and your smartphone or tablet's Bluetooth settings.
