Tracking an inReach Device from the Tread XL - Baja Chase or Race Edition
These steps are for the use case of tracking another inReach® satellite communicator, such as an inReach® Mini, from the display of a Tread® XL - Baja Chase and/or Tread® XL - Race Edition GPS Navigator.
This means the inReach device can be seen by the Tread XL - Baja Chase and/or Tread XL - Race Edition device but the inReach device will not see the location of the Tread XL - Baja Chase and/or Tread XL - Race Edition device.
NOTES:
Both the inReach device and the Tread XL - Baja Chase and/or Tread XL - Race Edition device must be in the same Group for the Team Tracking feature to work.
Team Tracking Intervals will display the location of the devices(s) in your Garmin Explore™ account Group you are tracking.
Team Tracking Interval is the time between update requests, users should expect additional data transfer times and are based on the Flex Team Plan associated with the device(s).
Team Tracking Interval ranges can only be changed by changing the Flex Team Plan associated with the device.
Step 1:
The Tread XL - Baja Chase and/or Tread XL - Race Edition device must be on a Professional Account with an active Flex Team plan. See Pro/Flex Team Tracking Activation.
Step 2:
To track an inReach device on a Tread XL - Baja Chase and/or Tread XL - Race Edition device, the inReach device must be added to the same Professional account as the Tread XL - Baja Chase and/or Tread® XL - Race Edition device is associated with AND have an active PRO plan subscription.
inReach device already associated with a Personal account?
See Switching My inReach Subscription From a Personal Account to Professional Account and then follow the applicable steps in Pro/Flex Team Tracking Activation to add the inReach device to the existing Group associated with the Tread XL - Baja Chase and/or Tread® XL - Race Edition device.
inReach device not associated with a Professional account?
Follow the applicable steps in Pro/Flex Team Tracking Activation to add the inReach device to the existing Group associated with the Tread XL - Baja Chase and/or Tread XL - Race Edition device and to activate a PRO plan subscription.
Example of how this will look in Garmin Explore
Groups & Users Tab:
Plans & Devices Tab:
