Pairing Your Smartphone
You should connect your Forerunner device to a smartphone to complete the setup and use the full features of the device.
  1. Go to www.garmin.com/intosports/apps, and download the Garmin Connect™ Mobile app to your smartphone.
  2. From the Forerunner device, select Menu > Settings > Bluetooth > Pair Mobile Device.
  3. Open the Garmin Connect Mobile app.
  4. Select an option to add your device to your Garmin Connect account:
    • If this is the first device you have paired with the Garmin Connect Mobile app, follow the on-screen instructions.
    • If you have already paired another device with the Garmin Connect Mobile app, from the settings, select Garmin Devices > Add Device, and follow the on-screen instructions.
