My eTrex Touch is in the Wrong Language
If your eTrex® Touch outdoor handheld is set to the wrong language and you need to change it, the below instructions will guide you through selecting the correct language. If the language is incorrect on your first usage of the handheld or you are unable to change the language using the steps below, see Related for steps to reset the eTrex Touch handheld. You will be prompted to select a language after the reset, during initial setup.
Changing the Language
- Press the
key to open the app drawer.
- Tap
- Tap
- Tap the second item in the menu.
- Tap the desired language.
