Pairing Forerunner 35 with Garmin Connect Mobile
When paired with your device, the Garmin Connect Mobile app can wirelessly upload and share fitness data with the Garmin Connect website as well as send smart notifications from your smartphone to your wrist.
To pair your Forerunner 35 choose your phone's platform:
iOS:
  1. Place the iOS device within 10 ft. (3 m) of the Forerunner 35
  2. Ensure that Bluetooth is enabled on the iOS device (see iOS device manual for details)
  3. On the iOS device, open the Garmin Connect Mobile application
  4. Touch the More icon in the lower right corner
  5. Touch Garmin Devices
  6. Touch Add Device
  7. Touch Browse all compatible devices
  8. Touch Forerunner
  9. Touch Forerunner 35
  10. Complete the Personal Information if requested. This allows the Forerunner 35 to assign personalized goals and learn your activity level.
  11. Touch Next
  12. On the Forerunner 35, press and hold the Menu button
  13. Press the down arrow button to locate Settings
  14. Select Settings
  15. Select Bluetooth
  16. Select Pair Smartphone
  17. Touch Start in the Garmin Connect Mobile application
  18. Touch Yes after verifying the passkeys match
  19. Touch your choice for Activity Tracking
  20. Touch Done
Android:
  1. Place the Android device within 10 ft. (3 m) of the Forerunner 35
  2. Ensure that Bluetooth is enabled on the Android device (see Android device manual for details)
  3. On the Android device, open the Garmin Connect Mobile application
  4. Touch the Menu button (≡) located in the upper-left corner
  6. Touch Add Device
  8. Touch Forerunner
  10. On the Forerunner 35, press and hold the Menu button
  11. Press the down arrow button to locate Settings
  12. Select Settings
  13. Select Bluetooth
  14. Select Pair Smartphone
  15. Touch Search for Device
  16. Touch Yes after verifying the passkeys match
  17. Touch your choice for Activity Tracking, if prompted
  18. Touch OK when the devices are paired
Windows:
  1. Place the Windows phone within 10 ft. (3 m) of the Forerunner 35
  2. Ensure that Bluetooth is enabled on the Windows phone (see Windows device manual for details)
  3. On the Windows phone, open the Garmin Connect Mobile application
  6. Touch Add Device
  7. Touch Brows all compatible devices
  8. Touch Forerunner
  10. With the Forerunner 35 in Pairing Mode, touch Add Device
  11. Once discovered, touch the device to pair.
  12. When requested, type or verify the PIN displayed on device and touch Allow
  13. After connection is successful, touch Close and continue
  14. If connection fails, touch Close and troubleshoot pairing
  15. If permissions are requested, touch Yes
  16. Wait for Setup and initial Sync to complete
  17. Once pairing is complete, touch Done
  18. Device is now Paired and Ready
You have now successfully paired the Garmin Connect Mobile application with your Forerunner 35, and the device can now sync.
