Importing GPX Files into Garmin BaseCamp and Transferring the Data to a Garmin Outdoor Handheld
GPX files can come from a variety of sources and contain data such as routes, tracks, waypoints, and geocaches.
These files can be imported into our BaseCamp™ software to review on a computer and then transferred to a compatible Garmin handheld.
Importing GPX Files
First, you need to import the GPX file(s) into BaseCamp with the steps below.
  1. Open BaseCamp.
  2. Select the File drop-down menu from the top toolbar.
  3. Select Import...
  4. Browse to the GPX file location from the Import File window.
  5. Select Open for Windows, or Import for Mac.
Once the GPX file has been loaded, you should then be able to transfer the data to your handheld.
Transferring GPX Files to a Garmin Outdoor Handheld
Now you can select the data and transfer it with the steps below.
Windows
  1. Connect the Garmin handheld to your computer.
  2. Select the data to send.
    • To send one or more items, or a list:
      1. Select an item, list, or multiple items (using CTRL+Click or Shift+Click).
      2. Select the Device drop-down menu.
      3. Hover over Send To Device.
      4. Select Send ['Name'] to Device, or  Send Selection to Device.
    • To send all saved data:
      1. Select the My Collection folder.
      4. Select Send 'My Collection' to Device.
  3. Select the device to which you want to send the selected data.
  4. Select OK.
The selected data will now be transferred to your handheld.
Mac
    • To send one or more individual items:
      1. Select a list, or the My Collection folder.
      2. Select an item, or multiple items (using Command+Click or Shift+Click).
      3. Click and drag the highlighted items to the Garmin in the upper left-hand corner.
      2. Select the Transfer drop-down menu.
      3. Select Send ['Name'] to Device.
      4. Check the boxes for the data you want to send.
      5. Select Send to send a list of all saved data to the Gamin.
Accessing Transferred Files on a Garmin Outdoor Handheld
NOTE: If Route Planner is not a listed application on your device after transferring route data, it can be added to the main menu on most devices. For steps, see - Options Are Missing From the Main Menu on My Outdoor Handheld.
  • Transferred waypoints can typically be found under Waypoints or Waypoint Manager on the handheld device.
  • Transferred routes can typically be found under Routes, Route Planner, or Courses on the handheld device. If your device does not support routes, the routes will automatically be converted to Courses on the device.
  • Transferred tracks can typically be found under Tracks, Saved Tracks, Track Manager, or Courses on the handheld device. If your device does not support tracks, the tracks will automatically be converted to Courses on the device.
  • Transferred Geocaches can typically be found under Geocaches or Geocaching. If the transferred geocaches are not listed there, check under Waypoints or Waypoint Manager on the device.
Related
