My T5 Collar is Damaged and Needs to be Replaced
If your T5 collar (not T5X) has become damaged (dropped, run over, etc.) and needs to be replaced, if you are within the United States you can use the link below to create an Return Material Authorization (RMA) to get your unit replaced.
You will need the Serial Number for your unit from under the collar strap.
Request replacement online here .
