Select Sign In, then sign in to your Garmin Connect account.
Garmin Express protects the saved Wi-Fi network credentials on your Garmin Device by requiring a sign-in to your Garmin Connect account before the networks will be displayed.
NOTE: Disable Bluetooth® if the device is paired to the Garmin Connect app. This will prevent the activity from being uploaded via Bluetooth instead of Wi-Fi.
Record and save a 20-second test activity on your Garmin device.
Wait approximately 30 seconds for the device to establish a Wi-Fi connection and transfer the activity.
If successful, the device will display a message indicating the transfer is complete.
If one minute elapses without the device displaying a message, check Garmin Connect to see if the activity appears.
If the activity appears in the Garmin Connect account, Wi-Fi is functioning properly.
My Activity Does Not Appear in Garmin Connect
If the activity does not appear in Garmin Connect, either the Wi-Fi connection is failing, the date on the device is wrong, or Garmin Connect is unable to accept the upload at this time
Check the Garmin Connect Status Page to verify there are no outages. If there is currently an outage, you will need to wait for the issue to be resolved.
Ensure that the date reported by the device is correct.
If the date is incorrect, activities will be processed and uploaded, but will be sorted under the wrong date in Garmin Connect.
If an activity was recorded and the device was away from the Wi-Fi for over an hour, the activity will not automatically upload. You will need to activate a manual Wi-Fi sync on your device.
