Garmin Motorize App Features
The Garmin Motorize™ app lets you control functions of your bike's built-in sat nav.
To get started with the app, see: Setting up and Pairing the Garmin Motorize App
The app can project navigation to your motorcycle via wired projection, or wireless projection.  See Navigation Projection with the Garmin Motorize App.
Select the following available features for information.
Garmin Real Directions™
  • Get spoken turn-by turn directions through your connected helmet or headset.
  • Meanwhile, navigation features are projected to the motorcycle meter panel when your compatible smartphone is connected to your motorcycle via USB cable or Wi-Fi®.
  • The navigation uses visual points for orientation like traffic lights or buildings.
Live Traffic
  • Avoid traffic delays and find timesaving detours to help keep you on your way with live traffic updates.
Photoreal Junction View
  • The feature displays the appropriate lane to drive in during an active route.
  • Junction view realistically depicts junctions and interchanges along with your route, including road signs and the surrounding landscape.
  • A brightly colored arrow indicates the lane needed for your next turn or exit.
Rider Alerts
  • Get alerts for hazards along your route, such as upcoming sharp curves.
  • You'll also be notified about speed limits, speed cameras, or nearby schools.
Fuel Tracking
  • Estimate the distance you can travel before running out of fuel and suggest fuel stops based on fuel range when connected to the motorcycle.
Live Weather
  • Real-time updates show weather, humidity, and daily forecasts.
