Fusion® Product Current Consumption
Important Notes:
All Fusion® stereos and amplifiers have a standard voltage rating of 10.8VDC to 16VDC unless otherwise stated
All figures are for the individual units only
All marine stereos with 4 amplified speaker outputs have been tested with 4 4-ohm speakers attached and no USB devices connected
If an external amplifier is fitted refer to its values for expected current draw
All measurements are maximum
Values are subject to change without notification
A field filled by a * asterisk indicates that that an accurate estimate cannot be given due to the number of possible variables such as volume, gain/level settings, number of speakers, speaker power, and more
Product | Standby or Ignition OFF | Stereo Muted | Stereo playing volume level <12 with 4 Ohm speakers | Max current draw |
Stereos | ||||
MS-RA770 | 0.2A | 0.75A | 2A | 15A |
MS-RA670 | 0.2A | 0.7A | 2A | 15A |
MS-WB670 | 0.2A | 0.7A | 2A | 15A |
MS-SRX400 | 0.2A | 0.4A | 1.5A | 10A |
MS-AV755 / UD755 | 0.2A | 0.75A | 2A | 15A |
MS-AV650 / UD650 | 0.2A | 0.75A | 2A | 15A |
MS-RA210 | 0.1A | 0.4A | 2A | 15A |
MS-RA205 | 0.25A | 0.75A | 3A | 15A |
MS-BB300 | 0.25A | 0.75A | 3A | 15A |
MS-RA70 | 0.005A | 0.75A | 3A | 15A |
MS-RA70N / RA70NSX | 0.015A | 0.75A | 3A | 15A |
MS-RA55 | 0.005A | 0.75A | 3A | 15A |
MS-RA60 | 0.01A | 0.2A | 2A | 15A |
Remotes and Accessories | ||||
ERX400 | 0.1A | NA | 0.1A | 1A |
MS-NRX300 | 0.035A | NA | 0.1A | 0.15A |
MS-BT100 | NA | NA | 0.06A | 0.1A |
Amplifiers | ||||
SG-DA12250 | <1mA | 2.5A | * | 120A |
SG-DA41400 | <1mA | 2.5A | * | 80A |
SG-DA51600 | <1mA | 2.5A | * | 80A |
SG-DA61500 | <1mA | 2.5A | * | 75A |
SG-24DA61500 | <1MA | 1.25A | * | 35A |
SG-DA82000 | <1mA | 2.5A | * | 100A |
MS-AM806 | <1mA | 1.5A | * | 45A |
MS-AM504 | <1mA | 1A | * | 50A |
MS-AM402 | <1mA | 0.5A | * | 25A |
MS-AM702 | <1mA | 0.25A | * | 10A |
AP-DA214 | <1mA | 0.1A | * | 10A |
MS-AP12000 | <5mA | 1.5A | * | 87A |
MS-AP41200 | <5mA | 1.5A | * | 53A |
MS-AP61800 | <5mA | 1.5A | * | 78A |
MS-AP82400 | <5mA | 2A | * | 104A |
