Sending a Location on a Rino 100 Series
Using a Rino® 100 series outdoor handheld you can send any location that you have available in your Find ‘N Go menu. These may be waypoints, contacts, cities, exits, or any other data that is loaded in the unit. Below are the steps to send a waypoint.
To Send a Location (Waypoint) Using Find ‘N Go
- Press the Thumb Stick In and hold it until the Shortcuts Menu is displayed, or press the Page button until the Main Menu is displayed.
- Highlight Find ‘N Go and press the Thumb Stick In.
- Highlight Waypoints and press the Thumb Stick In.
- Select Nearest or By Name and press the Thumb Stick In.
- Highlight the waypoint that you want to send and press the Thumb Stick In to display the Waypoint Review page.
- Highlight the Option Menu button
- Select Send Location and press the Thumb Stick In
The location is sent to all Rino handhelds on the same channel and squelch code as you. They can then choose to Goto that location, view the location on the map (Map), or save the location (OK).
