Languages Supported by the Garmin eLog
The Garmin eLog App supports the following languages:
- American English
- American Spanish
- French Canadian
If you're using the Garmin eLog App on a smartphone, the app will use the smartphone's language setting to determine the language of the app. See your phone's documentation for information on changing its language setting.
If you're using the Garmin eLog App on a dezl device, the app will use the device's language setting to determine the language of the app. If you have the device set to any language other than mentioned above, the app will default to American English. To change the language on the dezl device, see the applicable FAQ below.
- dezl 780 and dezlCam 785: Changing the Text Language on an Automotive Device if you can't Read it
- dezl OTR800 and dezl OTR1000: Changing the Text Language on an Automotive Device if you can't Read it
- dezl OTR810 and dezl OTR1010: Changing the Text Language on an Automotive Device if you can't Read it
