Using a Garmin Transducer Y-Cable
12-Pin Transducer Y-Cable Part Number 010-12225-00/10
Y-cable for splitting out left and right SideVü™ sonar from two SideVü™ transducers to avoid engine lower unit or keel shadowing.
This Y-Cable works great with all 12-pin GT transducers – transom mount or thru-hull. Pair up to two GT3x's, 4x's, or 5x's. The Y-Cable divides the signals out.
From the right-side transducer, it uses the traditional disc, Clearvü™ technology, Right-SideVü, temperature sensor and Garmin ID
From the left-side transducer, it uses only the Left-SideVü
The -00 cable is rather long, ~30’, so keep that in mind when routing cables
The new -10 version is only 2m long and more suited for transom mount mount transducers
Both cables have “PORT” and “STARBOARD” stickers on the ends to make it easy to connect up for each side
No software setup required
It is possible to use a mix of transducers, but, only certain combinations will work as described.
Examples:
GT30 on starboard (right) side with GT30 on port (left) side
GT34 on starboard side with GT34 on port side
GT36 on starboard (right) side with GT36 on port (left) side
GT40 on starboard side with GT 30, GT40, or GT50 on port side. All use the same SideVü elements
GT50 on starboard side with GT 30, GT40, or GT50 on port side. all use the same SideVü elements
GT51 on starboard side with GT41 or GT51 on port side. Both use the same SideVü elements
GT52 on starboard side with GT52 on port side
GT54 on starboard side with GT54 on port side
GT56 on starboard (right) side with GT56 or GT36 on port (left) side. Both use the same SideVü elements
12-Pin Transducer + 8-Pin Transducer to 12-Pin Sounder Part Number 010-12445-33
Y-cable to connect an 8-pin 2-D-only transducer along with a 12-pin SideVü / Clearvü -only transducer into a single 12-pin (orange) port on a Garmin SideVü equipped sonar.
This cable only works with specific SideVü / Clearvü transducers. There are currently only three of those; the GT30, GT34, and the GT36UHD
This cable also only works with specific 2-D transducers. There are currently only 7 of those; GT8HW-IH, GT15M-IH, G12M-THF, GT15M-THF, Airmar P72, Airmar B60, And Airmar P79
Software setup is automatic with the GT8 and GT15. The Airmar transducers require a manual transducer selection
NOTE: This Y-Cable will not work with any GT or CV all-in-one transducer like GT40, GT41, GT50M, GT51M, GT52HW, GT54HW and GT56UHD.
NOTE: When using the 12-Pin + 8-Pin to 12-Pin sounder cable, user must manually select the transducer type they intend to use.
