Master Reset for T 5 Mini and TT 15 Mini Dog Tracking Collars
If the T 5 mini or TT™ 15 mini dog tracking collar is failing to operate as expected, corrupt data may be the cause. Performing a master reset will reset the collar to factory settings and clear data, resolving issues caused by corrupt data.
To perform a master reset:
  1. Ensure the device is powered on and flashing a green light
  2. Rapidly Press the power button 8 times
  3. Wait for light to turn solid red then begin flashing green again
  4. Allow the collar a clear view of the sky for 20 minutes
For an example you can go to the 2:30 point of this video.
After the master reset, the collar will need to be removed from the tracking handheld's dog list, and paired back in again.
  • Removing a Dog from the Dog List
    1. Select Dog List
    2. Select a dog
    3. Select Remove
