Using the Included Wired Remote Control with the Fusion® MS-BB100
The wired remote control that comes with the Fusion® MS-BB100 is required for the stereo to function properly. The length of wire on the included remote cannot be extended or shortened.
When selecting a mounting location for the remote control, observe these considerations:
- Even if it will never be used, the remote control must still be connected for the stereo to function properly
- The remote control must be mounted in a location where there is at least 70 millimeters (2.75 inches) of clearance behind the mounting surface
- If the remote control is mounted outside the cabin, it must be mounted in a location well above the waterline where it is not submerged
- If the remote control is mounted outside the boat, it should be mounted in a location where it will not be damaged by a dock, piling, or other pieces of equipment
