Navionics Boating: Map Orientation
The Navionics® Boating App provides the user with different options for viewing their position on the map.
  • North Up - Tap the GPS arrow button once to center your current position on the map.
  • Heads Up - Tap the GPS arrow button twice to enable Heads Up orientation. This will rotate the map on your screen in the direction the device is facing.
    NOTE:  Panning the map or using the pinch-to-zoom function will disable centered GPS position on the screen and Heads Up map positioning. Tap the GPS arrow button twice to re-enable this function.
  • Course Up - Tap the GPS arrow button three times to enable Course Up. This will place the direction you are travelling at the top of the screen.
    NOTE:  Panning the map or using the pinch-to-zoom function will disable centered GPS position on the screen. Tap the GPS arrow button to re-enable this function.
GPS button:
Location of GPS arrow button at bottom left of map screen
