Battery Model Recommendations for Vector 3/3S or Rally Series Power Pedals
Based on extensive testing, Garmin recommends the following battery types for the Vector™ 3 and Rally™ series power meter systems.
NOTE: Garmin recommends replacing all of the batteries at the same time. Do not mix the battery types.
  • Energizer CR1/3N (2L76), 1 per pedal
    • Most recommended battery type for the Rally series pedals.
    • Using this type of battery would significantly reduce fretting due to road vibration.
  • Energizer LR44 (A76BP or A76BPZ), 2 per pedal
  • Energizer SR44 (357 or 303), 2 per pedal
    • SR44 batteries have not been tested for battery life however are expected to last longer than LR44 batteries.
    • SR44 batteries may perform better in cold temperatures.
  • Varta LR44 (V13GA), 2 per pedal
What Is the Expected Battery Life for the Vector 3/3S or Rally Series Power Pedals?
Garmin expects up to 120 hours of battery life before you will need to change your batteries.
Note the following:
  • Battery life specification is with cycling dynamics enabled and riding in normal riding temperatures. Battery life can be extended if cycling dynamics are disabled.
  • Cold weather riding may reduce battery life.
For instructions on replacing the batteries on your system, see: Best Practices When Changing Batteries on a Vector 3 or Rally System
