Why Am I Seeing a Connect Sync Service Notification on My Android Phone?
Google has changed the way they notify you about apps running in the background, starting with Android 8.0 (Oreo). When your phone is running Android 8 or higher, you’ll receive a notification that says “Connect Sync Service” if you are running the Garmin Connect app in the background. The notification will look like this:
Why does the Garmin Connect app need to run in the background?
Garmin Connect runs in the background so that you can stay connected with key features such as smart notifications and weather on your Garmin device. It also enables your phone to automatically sync data from your device to your Garmin Connect account.
How can I turn off the notification?
To turn off the Connect Sync Service notification:
Open the Garmin Connect app
Select
from the upper left corner
Select Settings
Select App Permissions
Select Manage (does not matter which one that you select)
Select Notifications
Uncheck Device Connectivity
