Important Notice: Beware of Fake Garmin Ads!
Garmin Malaysia has received reports of fraudulent websites and advertisements circulating on social media, claiming to sell Garmin products at discounted prices. Do not click on suspicious links or provide personal information on unverified sites.
Always shop through the official Garmin website. Your safety is our top priority.
Compatible Crank Arms for the Garmin Vector/Vector 2 Power Meter System
Vector/Vector 2 offers standard and large pedal pod sizes in order to fit most crank arms. The standard pedal pods will fit crank arms 12–15 mm thick and 44 mm wide, while the large pedal pods will fit crank arms 15–18 mm thick and up to 44 mm wide. The image below will aid in identifying a crank arm's thickness and width:
Thickness and Width of Crank Arm
When installing Vector/Vector 2, ensure there is at least 5 mm of clearance between the chain and your crank arm, when the chain is in the largest chainring and the smallest cassette gear1. For Vector/Vector S systems, if washers are required they should always be installed between the pedal pod and crank arm to ensure that the pedal pod does not come in contact with the crank arm. The number of washers used should be addressed on a case by case basis. Never use more than two (2) washers per pedal. Additional fitment tools and compatibility resources can be found on the Garmin website.
1 Only applies to Vector/Vector 2 and Vector S/Vector 2S upgrade pedal
