Fusion® Apollo™ ERX400 Wired Remote Control Manual Software Updates
Fusion Apollo ERX400 Wired Remote Control software version 6.50.119
as of April 2, 2025
Download (99.00 MB)
View installation instructions and system requirements
Notes:
- USB Flash Drive: Ensure the USB Flash Drive is formatted to FAT32.
- PartyBus-Network Compatibility: All Apollo stereos must be updated to the latest version for the PartyBus-Network feature to function correctly.
- If the Fusion Apollo ERX400 software version is V6.20 or higher and is connected to a Fusion Entertainment network, Garmin BlueNet network or a Garmin Marine Network, it can be updated as part of a network update.
Change History
Changes made from version 6.40 to 6.50:
- Added numeric comparison to Bluetooth paring.
- Other improvements and bug fixes.
Changes made from version 6.30 to 6.40:
Changes made from version 6.20 to 6.30:
- Added support for software updates from Garmin MFDs.
Changes made from version 6.10 to 6.20:
- Removal of GMN setting in user settings menu. The ERX400 will auto detect GMN
- Other bug fixes and improvements
Changes made from version 6.00 to 6.10:
- User interface performance improvements
Changes made from version 5.90 to 6.00:
- Changes to the way radio presets are displayed for AM, FM & DAB. Station names are now included.
- Other bug fixes and improvements.
Changes made from version 5.80 to 5.90:
- General improvements and bug fixes.
Changes made from version 5.70 to 5.80:
Changes made from version 5.50 to 5.70:
- Updated splash screens.
- Added zone and device name suggestions.
- Added confirmation when deleting presets.
- Modified volume limit display.
- Other big fixes and improvements.
Changes made from version 5.40 to 5.50:
Changes made from version 5.10 to 5.40:
- Added NMEA 2000 Speed vs Volume settings.
- Added Keep Volume ratios setting.
- Added mono setting.
- Added zone gain setting.
Changes made from version 5.00 to 5.10:
Installation Instructions
- Download the update file to your PC/Laptop.
- Extract the zip file to a USB flash drive (format FAT32). A folder named Garmin will be created on the flash drive.
- Connect the USB Flash Drive to a USB Port of a Apollo stereo (MS-RA770, MS-RA670, MS-WB670 or MS-WB675) on the same network as the ERX400 remote.
- Go to the settings menu in the Apollo stereo and select Update>ERX Remote and confirm Yes. The update will be transferred to all ERX400 remotes on the network. The ERX400 remotes will reboot when complete.
System requirements
- IBM-compatible PC running Windows 2000 or later operating system and an available USB port.
