How to Remove the Prompt to Update to an Old Database Cycle on the G1000
When the Navigation data is updated on one or both of the bottom cards from a previous cycle, the G1000® flight deck is programmed to ask the pilot to activate the old data.
To resolve this issue:
  1. Remove the bottom SD cards out of the G1000 displays.
  2. One at a time, insert the SD card into a computer.
  3. Look for the "ldr_sys" folder on the SD card in the root directory. If found, delete the file.
  4. Reinsert the bottom cards into their respective displays on the G1000.
Related
