Customizing the Watch Face on the Garmin Enduro 2
The Enduro™ 2 watch offers the ability to customize what data is displayed on the watch face. The selected watch face may change what can be customized, what options are available, or how the data appears. The instructions below are for customizing the pre-loaded watch faces. For instructions on customizing watch faces that have been downloaded from the Connect IQ™ Store, see - How to Customize a Watch Face Through Connect IQ Store.
  1. From the watch face, hold MENU.
  2. Select Watch Face.
  3. Press UP or DOWN to navigate to other watch faces.
    • Select Add New if you would like to start from a minimal watch face.
  4. Press START/STOP, then select an options to customize:
    NOTE: All options are not available for all watch faces.
    • Select Dial to change the style of the numbers for the analog watch face.
    • Select Hands to change the style of the hands for the analog watch face.
    • Select Layout to change Layout of fields.
    • Select Seconds to change the style of the seconds for the digital watch face.
    • Select Data to change what data options appear.
    • Select Accent Color to change the color that is adjustable on the watch face.
    • Select Data Color to change the color of the data that appears on the watch face.
    • Select BKGD Color to change the background color.
  5. Select Apply to save changes.
For more information and examples of the different watch faces and data customization options, select the options below.
Available Watch Faces
When customizing the data on a watch face, you can touch specific areas of the display to change what data is shown.
NOTE: Example images were taken from a fēnix®, and the Enduro 2 will say "Enduro" in place of "fēnix" on the watch.
Watch FaceTouch Areas
fēnix 7 watch face example 1fēnix 7 watch face example 1 touch
fēnix 7 watch face example 2fēnix 7 watch face example 2 touch
fēnix 7 watch face example 3fēnix 7 watch face example 3 touch
fēnix 7 watch face example 4fēnix 7 watch face example 4 touch
fēnix 7 watch face example 5fēnix 7 watch face example 5 touch
fēnix 7 watch face example 6fēnix 7 watch face example 6 touch
fēnix 7 watch face example 7fēnix 7 watch face example 7 touch
fēnix 7 watch face example 8fēnix 7 watch face example 8 touch
fēnix 7 watch face example 9fēnix 7 watch face example 9 touch
fēnix 7 watch face example 10fēnix 7 watch face example 10 touch
fēnix 7 watch face example 11fēnix 7 watch face example 11 touch
fēnix 7 watch face example 12fēnix 7 watch face example 12 touch
fēnix 7 watch face example 13fēnix 7 watch face example 13 touch
fēnix 7 watch face example 14fēnix 7 watch face example 14 touch
fēnix 7 watch face example 15fēnix 7 watch face example 15 touch
Numbers inside circle showing time and other data.Numbers inside circle showing time and other data.
Watch Face Data Customization Options
Depending on the watch face you have selected, the data options may look slightly different compared to the examples below. Some watch faces may also include larger graphical data fields for things like VO2 max, Training Status, or solar charging information.
Data Field UTC
Universal Time Coordinated
Displays Universal Time Coordinated (UTC).
UTC is the successor to Greenwich Mean Time (GMT).
Data Field Respiration Rate
Respiration Rate
Describes how often you inhale and exhale in a minute.
Data Field Pulse Ox
Pulse Ox
Display your most recent Pulse Ox reading.
Sunset/Sunrise
Displays Sunset/Sunrise time.
An arrow will point down for sunset and up for sunrise.
Data Field Steps
Steps
Displays daily step count.
Data Field Floors Climbed
Floors Climbed
Displays floors climbed for that day.
Data Field Recovery Time
Recovery Time
Displays the number of hours left on recovery time.
Data Field Status Icons
Status Icons
Displays icons when alarms, Do Not Disturb mode, phone connection, or headphone connection are active.
Data Field Notifications
Notifications
Displays the number of notifications.
Notifications number will not be cleared until they are cleared from the phone.
Data Field Intensity Minutes
Intensity Minutes
Displays the number of intensity minutes generated for the current week.
Data Field Running Total
Weekly Running Total
Displays distance of all running activities for the current week, except Trail Run.
Data Field Cycling Total
Weekly Cycling Total
Displays distance of all cycling activities for the current week.
Data Field Heart Rate
Heart Rate
Displays the reading taken from the optical heart rate sensor (OHR).
The OHR sensor must be on to get a reading.
Data Field Day and Month
Day and Month
Displays the current calendar date and month.
Data Field Weekday and Day
Weekday and Day
Displays the current calendar date and day of the week.
Data Field Calories Burned
Calories Burned
Displays total calories burned for the day.
Data Field Calendar Notifications
Displays the time of the next calendar notification.
Data Field Battery Life
Battery Life
Displays the remaining battery life.
Can display days remaining or percentage.
Data Field Barometer
Barometer trending line and the barometer reading
Will display the current barometer pressure in millibars.
The barometer trend line considers the last 6 hours, broken into two 3 hour segments. If there is a 2.3 millibar change over the 3-hour segment, the line will curve up or down depending on the direction of change.
Data Field Altimeter
Altimeter Reading
Displays the current altimeter reading.
Data Field Weather High Low
Weather High and Low Temperatures
Displays the high and low temperatures for the current day's forecast.
Data Field Current Weather
Weather
Displays the current weather.
NOTE: If you delete one of the pre-loaded watch faces, the watch will have to be reset back to default settings to recover the watch face. See your owner's manualfor information about how to reset your watch to default settings.
