Troubleshooting an Issue Between a Garmin Automotive Device and a Bluetooth Headset
Troubleshoot in the Following Order if you Experience Issues Pairing a Bluetooth Headset/Helmet to Your Automotive Device or Encounter Issues While the two are Connected:
  1. Software Update
  2. Clear Pairing History
  3. Check Compatibility
  4. Check for Supported Audio Type
  5. Alternate Pairing Modes
Software Update
  • Ensure your mobile phone and headset have the latest software as well.
    • Consult your phone and headset owner's manuals for guidance on how to update.
  • Clearing the pairing history on the automotive device and the phone will establish a new Bluetooth session between the devices.
To Clear the Pairing History:
1. Touch Tools
2. Touch Settings
3. Touch Bluetooth
4. Touch Change
5. Touch the device you wish to remove
6. Touch Remove
7. Touch Yes
  • If the headset is also paired to your phone, it is also recommended to clear the pairing history for this device on your phone as well.
Check Compatibility
  • While Garmin cannot guarantee compatibility between your device and a particular headset model, as long as the headset supports the hands-free profile and has a Bluetooth version of 1.1 or higher, it should be compatible with your device.
Your Device can Receive the Following Audio Prompts Through a Bluetooth Headset:
  • Navigation Prompts - During navigation, when an instruction such as "Turn left in 500 feet" plays through the device, this prompt will be played in your headset.
  • Phone Calls - As long as your phone and headset are both paired to the device, whenever you receive a phone call, the phone audio will be played through the headset.
  • Music - Your device can receive mp3 / media audio through a Bluetooth headset.
    • Any audio played through the various media source options on the mp3 or media player on your device will play through the headset, as long as the two are paired.
  • Bluetooth headsets/helmets (especially those designed for motorcycle usage) will often have multiple Bluetooth pairing modes.
    • These are designed to give the Bluetooth accessory flexibility for different uses (phone, navigation, music, etc.).
    • It may be necessary to try the other pairing modes offered by your headset to find one that works best with your Garmin device.
  • The owner’s manual for your Bluetooth headset should include instructions on how to use these alternative pairing modes if it applies to your Bluetooth headset.
NOTE: A phone call is prioritized over any other audio.  The device will mute spoken navigation prompts when a call is active.  The visual on-screen navigation prompts continue.  Navigation prompts resume when the phone call is disconnected.
