1. Insert the SD card into the computer
2. Press the Windows key + E
3. Click This PC (Windows 10 or Newer)
4. Locate the drive representing the SD Card
- To determine which drive is the SD card remove the SD card from the computer and observe which drive disappears from the list then insert the SD card again.
5. Right-Click on the SD card
6. Click Format
7. Verify the File System is FAT or FAT32
8. Change Allocation unit size to Default allocation size
9. Ensure Quick Format is checked
10. Click Start
These steps will format the SD card to be readable by Garmin Express and the Suzuki Infotainment system.
If at any point during the format process an error is received or formatting the SD card fails to resolve the issue, try another SD card.
