Showing the Track of Where I've Been
The DriveTrack 70 and DriveTrack 71 can show a track of where you've been. This is called the Trip Log. Trip Logs can be used to determine the path you have taken if you get lost.
Two settings need to be adjusted to show the Trip Log.
Enable Travel History
Enabling Travel History allows the DriveTrack to log the path you have taken.
  1. Touch Settings
  2. Touch Device
  3. Touch and enable Travel History
Show the Trip Log
Showing the Trip Log will display the path you have taken on the map.
  1. Touch Settings
  2. Touch Map & Vehicle
  3. Touch Map Layers
  4. Touch the box next to Trip Log to hide or display the log on the map screen
  5. Touch Save
The Trip Log should now appear on the map as a blue line.
Clearing Travel History
At times you may need to clear the Travel History to remove clutter from the map.
  1. Touch Apps
  2. Touch Where I've been
  3. Touch the Menu Lines
  4. Touch Clear Travel History, and confirm
Related
