Can I Overlay an Approach Plate on the map in FltPlan Go?
Yes, you can Overlay an Approach Plate on the map in FltPlan Go in a couple of different ways:
- Tap on the arrival airport.
- Select View Procedures.
- Tap on the approach to overlay on the map.
OR:
- Enable the Airports layer.
- Go to Maps.
- Go to Layers.
- Go to Airports.
- Tap on an airport icon on the map and select View Procedures.
Note: Only geo-referenced approaches will display on the map. There will be a Procedure Options menu (bottom right) that will allow you to adjust the approach.
